This command configures the number of lines and columns for the current login session only.
lines | Number of lines on the screen. |
height | Height of the screen. |
columns | Number of columns on the screen. |
width | Width of the screen. |
N/A.
The screen size specified takes effect over whatever screen size the session may have started with or whatever the current settings may be. If the terminal emulation supports dynamic resizing of the window, this will cause the size set by this command to be overriden. The command accepts either lines or columns or both in either order.
The show management command has been enhanced to display the current screen size:
# show management CLI idle timeout : Enabled (20 minutes) CLI max number of login attempts : 3 CLI max number of sessions : 8 CLI paging : Enabled (this session only) CLI space-completion : Disabled (this session only) CLI configuration logging : Disabled CLI password prompting only : Disabled CLI scripting : Disabled (this session only) CLI scripting error mode : Ignore-Error (this session only) CLI persistent mode : Persistent (this session only) CLI prompting : Enabled (this session only) CLI screen/window size : 80 Lines 256 Columns (this session only) CLI refresh : Enabled Telnet access : Enabled (tcp port 23 vr all) : Access Profile : not set SSH Access : ssh module not loaded. Web access : Enabled (tcp port 80) : Access Profile : not set Total Read Only Communities : 1 Total Read Write Communities : 1 RMON : Disabled SNMP access : Enabled : Access Profile : not set SNMP Notifications : Enabled SNMP Notification Receivers : None SNMP stats: InPkts 0 OutPkts 0 Errors 0 AuthErrors 0 Gets 0 GetNexts 0 Sets 0 Drops 0 SNMP traps: Sent 0 AuthTraps Enabled SNMP inform: Sent 0 Retries 0 Failed 0
This command was first available in ExtremeXOS 16.1.
